Results 1 to 3 of 3
Thread: tuning problem????
    Sep 2013
    Chehalis WA
    tuning problem????
    Have been trying to fix this problem for months and was hoping someone on this forum might have some insight or advice. I'm trying to tune with evoscan as I usually do but out of nowhere it wont stay connected. I can start the car and drive around all I want with no issues but as soon as I do a pull it disconnects. The weird thing is it will stay connected if I do a high gear pull at low boost. Have tried different laptops and Have tried monitoring only one sensor at a time, no change. Even simple suggestions would be appreciated.
    mods-
    Billet DR-650's
    Wastegate Upgrade Kit
    HKS twin power
    NGK Plugs (Heat Range 7)
    ARC-2 83MM MAS (DR version)
    3SX Stainless Steel YPipe
    Krank Vents System
    Vac reduction
    EGR Blockoff Plates
    walbro 255 Hotwired
    Devils own progressive W/M inj
    HKS EVC-S boost controller
    J&S Safegaurd
    ebay exhust
    boost guage
    AEM Wideband
    manual oil pressur gauge (psi!)
    AEM fuel pressure gauge
    AEM AFPR
    Bell Housing Brace
    XTD stage 3 clutch
    Setrab 920 oil cooler
    recent maintenance-
    02 sensors
    PTU
    Coilpack
    head gaskets
    head bolts
    120k
    VSS
    3rd gen lifters
    cam seals
    main/rod bearings,and thust washers (clevite 77 coated)
    oil pump
    rear main seal
    tranny mount
    carrier bearings
    ball joints
    tie rod ends
    shocks (kyb)
    spark plug wires
    fuel filter
    oils-redline mtl/mt90, shockproof
    Is Evoscan tossing you an error message or simply disconnecting with no warning?
    Sep 2013
    Chehalis WA
    simply disconnects. After it disconnects it can take anywhere from 1-20 attempts to re-connect too.
