1995 $ 6300
starting to post on my car that is going up for sale. just purchased a 04 mystichrome terminator.
1995 RT/ TT
6300 car only cash. 8k with spares/stocks and extras.
putting it for sale on CL for 10K!!
daily driving the car.
NEW everything under the front end suspension wize.
last dyno was 317AWHP should be making 20HP more since then.
New tires(last month. hankook evo 110's)
. new odyessy PC680 MJ battery less than a year.
entire new front end bits.
fresh clutch/flywheel. stage 2.5 sprung hub. LW flywheel.
1 year old paint. Lexus diamond white pearl with a touch extra blue pearl.
corbuea CR1 wides. reworked brackets to fit fine.
99 nose. 575 hood with areolatches.
shaved antenna with hidden amp antenna.
shaved ALL emblems and filled in 99 mitsu nose.
I work at a dealership and change the oil with fram filters and rotella T6.
trans fluid was done with clutch 2 years ago.
rear diff and trans done in feb.
EVERY OPTION. removable roof. 18 inch stealth chromies. 6 disk leather.
spare/extras include
stock 1995 TT 18 inch chromies.
extra 95 stealth headlights
2 sets of 2g VR4 heads with cams.
DNP SS pre cats.
60K oem kit with gates belt.
skillard 95 stealth/99 nose splitter.
SMIC. and
rebuilt polished fuel rail
sand blasted ready to remount or coat 95 upper and lower TT intake.
box of stuff from a complete 97 motor i purchased. sold block to midwest turbo.
sold turbos localy rest of the motor is in the tubs. VC and everything.
255LPH walbro pump to be installed.
extra good running 6 speed xfer case.
trans shifts good. car pulls STRONG. never over heated in florida traffic.
the a/c will make my wife bitch about being cold.
previous owner installed a 97 motor in the car. with fresh rebuilt turbos about 5 years ago.
car currently has this stuff i can remember.
CX FMIC racing.
HKS SSQ BOV.
customer made maffless pre turbo pipes.
MAFT with guted ported 3 inch GM in blow thru.
SAFCii.
rebuilt and flow matched 1 year ago 450CC DSM injectors.
gutted precats. no main cat and 3 inch single shot exhaust
recently fresh 9b's.
hot wired pump.
click click no start.
Tien springs
Tien pillowball strut mounts.
solid subframe bushings.
KYB GR2's up front.
MBC 19-20PSI
vac redux.
55W HID kit.
short shifter.
ported lower intake manifold.
solid motor mounts.
new front axles. with suspension.
EGR delete and block off.
6.5inch component in the stock front location and tweeters in the stock upper speaker location
new 2 month old:
inner outter tie rods
sway bar end links.
ball joints.
full poly front control ar bushings,
new steering rack bushing.
new sway bar bushings.
new power steering hoses.
new axles.
was almost 2000K$ put into front suspension 2 months ago.
car is set to add a set of turbos and make 400HP. was the goal.
but i ran across a mystichrome 04 terminator for 20$ sitting at a nissan dealership!!
i have many posts following my build on the other unmentionable forum.
the PREVIOUS 2 owners of this car are/were both members of that forum. and i can track this cars history back to 1998 on there.
I will provide those user names to the purchaser.
I have a FULL CAR FAX. NO ACCIDENTS EVER..
Be serious and have cash.
Bad stuff/ open honesty,.
when installing the front end my mechanic said i have a small steering rack leak. i knew i had a leak its why i put the hoses on. needs like 3-4 ouches of PS fluid every oil change.
he also said i need to do my 60K. so i purchased last month
a full 60K kit from maximal with gates belt and OEM other stuff. was 500$
the speed sensor plug melted on the P/O so the speedo is inop.
a wheel ABS sensor is bad, dunno which one. never cared. ABS will pop once the car moves.
uhhh. the stock original radio volume knob is delicate. will go down fine. hard to spin it to get it up. planed a nice stereo install one day. but meh.
serious buyers. have a check. can help with delivery.
pictures to follow.
no trades unless you have a Kenne bell 2.8!
