Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: 99 euro ecu support
    It's compatible with cars without an immobilizer.
    Jesters is working on a Euro ECU that will disable the immobilizer too!
    Well looking at my setup i recon as mentioned before the JDM GTO doesn't have a separate immobiliser check circuit external to the ECU (to my limited knowledge) but the
    UK 3000GT does (correct me if im wrong here)
    Given the opportunity I want to test this by plugging in my ECU to a 3000GT to see if it runs at all, need a volunteer now lol.
    Im not planning on running huge power, something around 450 will suffice. If any of the developers need any code testing on the car let me know im willing to help out.
    Oct 2010
    St Louis
    Actually you can disable the immobilizer vis code. .. This is not unique to the hardware.
    The Eclipse guys have been doing this for years... There is a table where the immobilizer code is held. .. And this can be bypassed
    Sent from my SPH-L720 using Tapatalk
    www.ClonedECU.com
    The home of the Original Clone and Clone2 ECU!
    More Plug n' Drive and less Plug n' Fail like the others!
    Remember, if it's not a Clone, it's just a copy!
    Get Chromed!
    Donate Now and receive a coupon code for the amount of your donation (up to $50.00 US) which you can apply at check out for a Clone2 ECU, Plug n’ Play Harness, or Clone2 Plug n’ Play Package!!
    1999 3000GT VR4
    Glacier Pearl White
    Yeah it's stock . . . trust me
    How To Contact Me:
    eMail: brett_farnam@yahoo.com
    US3S/3SGTO: 99 vr4
    3SI: bfarnam
    I lack color... verified
    Aug 1998
    Quote Originally Posted by 99 vr4 View Post
    Yes Brett...
    ...but they can't run chrome on their ECUs.
    Oct 2010
    St Louis
    Had nothing to do with Chrome...
    Tephra v5.10 96260009 ROM has an example. ..
    Just need to add the table definition to the ECU Flash XML file and turn off the immobilizer....
    Also why can they not run Chrome
    Aug 1998
    Oh so people are going to run an EVO 8 rom on their euro 3000GT. Got it.
    What about the non-flashable ecu 3000GT guys with the immobilizer?
    Oct 2010
    St Louis
    Your not getting it. .. Non Flashable.. Convert to Flashable, disable immobilizer.. done
    The EVO guys have been doing this for a while swapping hardware back and forth between vehicles that came equipped with immobilizers and those without. ..
    Aug 1998
    I never knew the immobilizer could be disabled in the code. That's like... whoa!
    As a side note guys would be interesting to know where this mysterious box for the immobiliser is actually located?
    Aug 2011
    Quote Originally Posted by The-Stig View Post
    It's attached to a bracket where the ETACS module is mounted. You'll probably have to pull the knee panel under the steering column to get a good look at it.
    It might actually be piggy-back on the rear side of the ETACS module, facing the firewall. It's tough to tell from the diagram I have.
    Hi, another quick update. Managed to install and test blackstealths LCDBC on my Chrome euro ECU...
    1467343_10151899505898580_89841177_n.jpg1472887_10151899506068580_567638468_n.jpg1468745_10151899506498580_1033339525_n.jpg1465150_10151899506318580_909882545_n.jpg
    Waiting for LC-2 to fit shortly and wire in the wideband to the ecu and the LCDBC.
    So im guessing no one knows where the immobiliser unit is situated on the car then?
