Is it safe if my exhaust temperature is around 900-1100'F cruising on freeway at 70-80 mph?
What are you measuring it with?
-SP
Perfectly fine.
I am measuring with a Depo egt gauge.
But when I try to down to 4th gear and full throttle, it goes all the way up to close to 1200'F and there is always some kind of a weird sound at the back once I go up to 1100~~~'F??? Btw, I have a catless downpipe and a single shot exhaust.
Here's a thread about it.
http://www.3sgto.org/3000gt-stealth-...t-reading.html
a bit hot for me.
Funny that everyone has made a comment on temperature and no one has a clue where the bung is. Mine is literally 2-3 inches from the exhaust port on the head and I cruise around all the time anywhere from 1100-1400. Distance from the port is a large piece of information that is missing from this puzzle. Stoich is the "optimum" AFR because it is supposed to burn everything. More fuel burning means higher EGT's. More load also means higher EGT's but, the fact that WOT is typically richer than stoich means there is still heat that can be made from combustion. I don't recommend running stoich at WOT but it is fact.
My opinion, until OP states where the bung is this info is useless.
Jeff
