Well crap the speedometer mount broke does anyone have the Mitsubishi part # for this. It's the part on the right that the shaft and sensor attach to. The AL tab where it bolts to trans broke off had a crack in it.
Where are you located?
Kalamazoo Michigan
Feeling stupid but just not having luck. Need to get the shift lugs lined up in Neutral so I can put the shifter assembly back in but no matter how hard I try with a screw driver or socket extension I can't get them to line up like in the manual. I've thought about pulling the cover on the springs / bearing to see if that helps.
How do you line them up what am I doing in correctly?
The detent plate and bearings/springs needs to be removed to ensure the shift rails are fully seated. If they won't align its possible to have a ball wedge itself under a shift rail. It's also possible a shift fork is bound on a hub slider or the shifter assembly guide is still positioned and the shifter is being blocked.
You can also reach out to Tim Zimmer...aka TMZ performance. Tell him nomie sent you...he knows his stuff really well. Check out his website and give him a ring...
tmzperformance.com
He is near milwaukee
