How big is the hole? Weldable?
As for swapping bearings....easiest way to remove races is to put case in oven ad heat until races drop out....then heat the new case and chill races and they drop in.
Download the manual, you'll need it to set clearances. FYI, I never remove the dowel pins, never had a need to.
