Results 1 to 10 of 17
Thread: New "mid-boost" Supra Dyno #'s
    Got my Supra back on the dyno with the fuel system and the old school turbo (replaced my short-lived dbb 6266) for some "mid-boost" tuning
    Pertinent mods:
    PTE 74GTQ .81ar -- old school dinosaur-tech..!
    PHR turbo kit - (new style) open tubular manifold, single gate
    4” dp/mp; Apexi N1 catback (necks down to 3” at the flange and then to 3.15”)
    GReddy 3-row
    Gforce ECU; VPC/AFC NEO
    GSC S1 cams
    GSC Beehive springs & Ti retainers
    SupraStore fuel system -- 880cc injectors, Wally 400
    VP110 fuel
    100% STOCK Ignition - 4644's gapped at .032 - NO DLI!!
    Boost numbers are peak boost, per the Peak-Hold on my EBC:
    18.2psi 582WHP 471WTQ
    19.3psi 597WHP 488WTQ
    20.3psi 602WHP 504WTQ -- Fattened A/F
    22.4psi 650WHP 523WTQ
    23.4psi 675WHP 539WTQ
    24.2psi 692WHP 551WTQ
    24.8psi 700WHP 558WTQ
    Switching to C16 before turning it up further. Can't wait to see what 30psi will do..!! I'll try to get it back on the dyno in a few weeks and go for KILL numbers! Should do ~800WHP on KILL.
    Here's the 700WHP Graph:
    Video:
    Formerly:
    August 2010
    Chicago
    wow...killer numbers man...so jealous.
    SDSU Alumnus verified
    Nov 2006
    Chula Vista SD, CA
    Damn Abram lol. Any pictures until then?
    Very nice my friend!
    That's pretty damn flat...
    Oct 2011
    Sundsvall, Sweden
    That looks really smooth, give us a video!
    Thanks, fellas. The car is an absolute blast to drive -- doesn't make a ton of TQ so it hooks up nicely, and absolutely rips up top! Looking forward to some C16 and 8xxWHP. I'll have the video up as soon as I get a chance to put it together. I'll try to get some more of the graphs up tonight.
    August 2010
    Chicago
    What is it that allows you to keep tq curve from dropping like a rock? is it common for the 2jz or is it the cam/turbo combo, or what?
    TQ doesn't drop like a rock because the setup is still very very efficient and well-matched. The cams play a part, but the engine is still breathing well and exhaust back pressure is still good. My old Supra with the T72 and stock cams still carried TQ fairly well. The reason say a TD04 setup looks like a bellcurve is because the stock cams were made for mid-range power, but even more paramount, the exhaust backpressure is sky high due to the teeny tiny turbine and exhaust housing.
    Here's some fun comparisons:
    Red: PTE 6766 jb .81ar @ 24psi, 264 cams, AEM w/ soft tune and VP110 (on a 213k mile engine)
    Green: PTE 6266 dbb .84ar @ 19psi, stock cams, stock fuel, VPC on VP110
    Blue: My current setup
