Hello all, I recently bought an AEM s1 for my JDM Gto Twin Turbo.
Looking at installing the MAP and IAT sensors the MAF connector looked like the ideal candidate as it has all the inputs needed and +5v for the MAP sensor..
Anyway after re-assigning Baro input to MAP sensor and setting up the scale with my Mitivac I started the car, the load scales instantly reacted to TPS instead..
Long story short, you have to use the Sensors/Barometric Pressure wizzard to assign the internal AEM Baro sensor first (even if you just zero the map out), before setting up the MAP calibration.
I wasted 1/2 a day on this re-wiring etc before the penny dropped so be careful!.
