That is my point, with the engine OFF I am seeing IDC's for the front bank. They start at about 4% and climb the longer I log.
The STFT and LTFT start near zero and move toward max negative -25. Again with the engine OFF.
The rear bank is doing what it should, all zeros. So upon investigation I noticed the front O2 is reporting a voltage or the ECU is seeing a voltage for the front O2. My theory is this is the problem causing the.IDCs and crazy fuel trims on the front back. I still need to track this further down.
Did it make more sense this time?
