I have been doing some logging on my 92 TT. I am using Greg E's setup file on EvoScan 2.9. I have noticed that my front bank fuel trims are all pegged at -25% except for the low whichs will read about -24.5%. The front bank IDC's are about 12+%.
The rear bank looks perfect, all fuel trims are +/- 4.5% and the IDC's are like 2-3% at idle.
Both O2s are new and cycle as the should and there are no major vacuum/boost leaks that I can find.
When in open loop, the IDC's match nicely from front to rear. I have always felt that this car transitions a little odd from closed loop to open.
Any ideas out there on what is going on?
The car also starts weird when warm, sometimes it almost binds like the timing is way advanced, other times it takes a bit of cranking to start and it will start at a low RPM and then come into it. It has very good power under boost, but has always felt a little off in closed loop.
Only mods are...
14 psi
Hotwired stock fuel pump
M2 exhaust
EGR delete
Vac reduction
Cone air filter
No cats at all
Thanks in advance for any help.
