Results 1 to 10 of 16
Thread: Built and restored 99 part out - top shelf parts!!
    I lack color... verified
    Aug 1998
    This thread is typed with a heavy heart. I picked up a 99 SL chassy earlier this year and began to completely restore the car from the frame out. The plan was to convert the car to an AWD VR4 show car putting down 600whp. Due to life changes (marriage, school, daily driver vehicle dying) I am afraid I can't complete this project.
    This is a list of all my stuff for sale. EVERYTHING IS BRAND NEW and shipping is NOT included!
    3.5 Pampena stroker short 4-bolt block - $5750 - save the core crank/block over making your own. The core block and crank were not spun bearing pieces ($1000 in core parts alone!) You will need to arrange freight shipping from Ray's shop where the engine currently resides.
    DR Stage 3 heads with Rays head lift fix - $2500 - core heads are from a 4 bolt motor that never had any timing issues. Ray charges $500 alone for the head lift fix so you're getting a deal! You will need to arrange freight shipping from Ray's shop where the engine currently resides.
    Powder coated engine and accessory brackets - $500 - This is every single piece of metal that's attached to the engine. Some pieces are black chrome and some pieces are metallic dark grey
    pics - https://scontent-a.xx.fbcdn.net/hpho...59435456_n.jpg
    https://scontent-a.xx.fbcdn.net/hpho...33835127_n.jpg
    https://scontent-a.xx.fbcdn.net/hpho...55789164_n.jpg
    https://scontent-b.xx.fbcdn.net/hpho...29068669_n.jpg
    https://scontent-a.xx.fbcdn.net/hpho...01996092_n.jpg
    (note the brown pieces are now black)
    DR 750s with stock Waste Gates - $3200 - these were made from brand new 13Gs NOT worn out 9Bs so you're saving $1400 right there! Shipping will be extra (PM me your zip code for a quote). Will consider selling with Forge 12psi wastegates for $300 extra.
    ARP Head studs - $330 - save yourself $10 from buying these from ANY shop
    Complete OEM engine gasket and accessory kit - $1300 - this includes 4 bolt oil pump, water pump, timing belt, ALL gaskets (rear main seal, head gaskets...). Even cherry hill can't get you this stuff for less than this.
    Stock 1G turbo cams and cam gears (rear exhaust cam has the blade for the hall sensor) - $100
    Walbro E85 Fuel pump - $180 - save yourself $10 over buying this anywhere else
    FIC 1050cc fuel injectors - $520 - save yourself $10 over buying these anywhere else
    RPS MAX Series Clutch Street 6 Puck Sprung Disc AWD
    Fidanza Flywheel AWD - Pairing these two together as they are barely used (50 miles on them total) for $1000.
    CX Racing wrinkle black powder coated turbo intake pipes - $120
    picture - https://scontent-a.xx.fbcdn.net/hpho...72113340_n.jpg
    CX Racing shocker yellow power coated SMIC pipes - $385 shipped
    https://scontent-a.xx.fbcdn.net/hpho...10891109_n.jpg
    (note: comes with blue couplers)
    Wrinkle red powder coated valve covers and matching fuel rails/thermostat housing pieces - 3000GT/Stealth International Message Center
    Shocker Yellow powder coated AWD subframes - $700
    pics - https://scontent-a.xx.fbcdn.net/hpho...28832397_n.jpg
    (Bushings will be $200 extra & AWS delete will be $40 extra)
    Rebuilt shocker yellow control arms - $300 - includes brand new Super Pro bushings and ball joint
    pics - https://scontent-a.xx.fbcdn.net/hpho...60101590_n.jpg
    VR4 front brake calipers, pads and rotors - $250 - PM me to discuss rebuilding and powder coating these calipers
    Black powder coated tein s-tec AWD springs with new OEM front struts (I haven't purchased rear struts yet) - $400
    As for the 99 SL chassy itself, it has about 125K miles and AFAIK has never been in an accident and has a clean/clear title. The flywheel exploded which put a hole in the hood. The paint still shines but has several scratches and dings. I have done a full black interior swap with 6 new OEM infinity speakers, AWD vac assisted clutch pedal assembly with NEW OEM master cylinder, ABS delete with OEM parts. I've sanded/derusted the entire chassy and sprayed fresh under body coating. Currently in the fuel tank is a like new OEM VR4 fuel pump assembly with a stock VR4 pump (the fuel tank is FULL of gas meaning there is NO rust). The fuel pump is hot wired and the wring is cleanly tucked with the fuel lines. Many of the bolts and brackets on this car have been cleaned and powder coated. Even the firewall insulation was degreased and painted flat black. This is a PERFECT chassy for whatever you can dream up.
    The chassy comes with a true 98 VR4 engine wire harness and Jesters 99 Clone ECU ($1000 worth of parts right here). It also comes with 6-speed shifter cables swapped in and the driver side half shaft needed for the AWD trans. The hole for the driver side IC is cut out and I do have a set of 99 style innercoolers and OEM turbo oil cooler I can include for extra. The car is missing the 99 heads and turns.
    I've swapped out all the lock cylinders on the car for good condition ones and the car has 3 keys and one keyless remote!
    Would like to get $1750 for the chassy.
    Pics:
    https://scontent-a.xx.fbcdn.net/hpho...91377264_n.jpg
    https://scontent-b.xx.fbcdn.net/hpho...10868574_n.jpg
    https://scontent-b.xx.fbcdn.net/hpho...96948767_n.jpg
    https://scontent-b.xx.fbcdn.net/hpho...84973696_n.jpg
    https://scontent-a.xx.fbcdn.net/hpho...87389498_n.jpg
    https://scontent-a.xx.fbcdn.net/hpho...31030482_n.jpg
    https://scontent-b.xx.fbcdn.net/hpho...62695971_n.jpg
    https://scontent-b.xx.fbcdn.net/hpho...76992803_n.jpg
    https://scontent-a.xx.fbcdn.net/hpho...44409173_n.jpg
    https://scontent-a.xx.fbcdn.net/hpho...46636061_n.jpg
    https://scontent-a.xx.fbcdn.net/hpho...60187959_n.jpg
    https://scontent-b.xx.fbcdn.net/hpho...04955756_n.jpg
    https://scontent-a.xx.fbcdn.net/hpho...36592362_n.jpg
    https://scontent-a.xx.fbcdn.net/hpho...73022951_n.jpg
    https://scontent-b.xx.fbcdn.net/hpho...33549985_n.jpg
    https://scontent-b.xx.fbcdn.net/hpho...83529634_n.jpg
    (note the poly motor mounts are not included)
    https://scontent-a.xx.fbcdn.net/hpho...29266625_n.jpg
    https://scontent-b.xx.fbcdn.net/hpho...56071838_n.jpg
    https://scontent-a-lga.xx.fbcdn.net/...19699682_n.jpg
    https://scontent-b-lga.xx.fbcdn.net/...75920639_n.jpg
    The car comes with a set of true black leather power seats. Driver side is worn. For $250 extra I'll include a perfect set of true black leather power seats (you'll get both sets of seats).
    If you would like to discuss purchasing this car as a turn key built vehicle, shoot me a PM. I want to see this thing go to a good owner!
    More parts and pics will be added as time goes on.
    Banned J. Fast's Avatar
    Some good stuff in here... GLWS!
    Aug 1998
    I have a potential buyer for the chassy. Control arms have sold.
    Damn so close! GLWS I am drooling over a few pieces....
    DC Metro Area
    Really wish I had the 9k available for the engine/turbos. Would be the last pieces necessary :-( Good luck with the sale. If either of them are still available around christmas, I may be able to afford 1 of 'em.
    You got married?
    I hate to see you sell this stuff.
    Jun 2012
    Broken Arrow
    how about the hood struts- are they in good shape?? No issues with holding pressure and keeping the hood up??
    Own cammed 3000GT NA; 84,000 miles without single scratch or dent.
    The real cars now: '09 Z06 LS7 Cyber Grey Metallic >> fast, but refined... 2015 Z/28 LS7 w/3.91's - its one bad azz car -fast rude and visceral..
    sucks. sorry to hear. glws!
    Greg did the chassis ever sell? If not you interested in selling the 99 front and turns? If so throw me a price. If we can work out a deal I would make the drive to pick stuff up.
    Albany, OH
    Yep..it sold
    "I never knew I could drive like that. I was going faster than I've ever gone before, and yet, it all seemed to be happening in slow motion. I was seeing three and four moves ahead, weaving in and out of lanes like an Olympic skier on a gold medal run. I knew I was challenging the very laws of physics."
