Results 1 to 10 of 11
Thread: No fuel
    Jan 2011
    az
    No fuel
    Whats up guys?? This damn car is crazy lol.. Ok so I thought my car was out of timing because it would backfire.. So I reset the timing. Now it's correct.. The car isn't getting fuel.. The #1 cylinder is getting fuel because the plug had some stuff on it and I plugged in the fuel injector light to test the harness. But when I plug the noid light into numbers 3 and 5 and turn her over , the light doesnt come on which means there isn't a signal going to the harness.. What could cause this? The ecu is good because I put it in another car and that car ran.. Could it be the cam sensor? It's a 92tt..
    Ross 9:1 piston, H beam rods with arp bolts, *Forged crank,*Ported head with brian crower 1mm over intake and exhaust valves,*Brian crower valve springs,Oem headgaskets,*Arp headstuds*,T3 hybrid turbos with .63ar,*Tial leaded fuel wastegates with 1bar springs,*Cx racing fmic*,Arc2 in blowthru,*950cc delphis on e85,Jackhammer fuel hanger holding 2 walbros 255 hotwired ,Fuel lab fpr,*Aeromotive fuel filter*Entire fuel system done in ptfe braided black lines,*Beefed up oil cooler,*Gates racing belt*,Ninja performance soild tension setup*,3sx single pass radiator*,Tial q blowoff*,Scanmaster*,Aem twin fire*,3sx fuel rails* battery relocated to trunk, blitz dsbc, aem wideband, autometer oil pressure gauge,And so on....
    Jan 2011
    az
    Bump..
    The signal to fire the injector is the Ecu grounding one of the pins. They all get a constant 12v from the mpi relay, through the resistor pack.
    One fix at a time verified
    Kansas
    Do you even hear the MFI clicking when you turn the car on? Probably since you get at least 1 injector to fire. You might check fuse 1 under the hood for the MFI relay. See if you get power at the relay using a multimeter next. I don't remember which wires are energized when you turn the key on and which when you crank. From there check the resistor box. It may be bad. I know someone had similar issues with a few injectors not firing and it was the injector box. I'm sure you can get your car running again without having to sell it.
    Also, if the car is running e85, the injectors can get stuck closed from sitting. You can open them with 12v, and blow wd40 through them if that's the issue.
    Medford OR
    Check for full current at the injectors... I use something that will load it down like an old headlamp.
    If it's not right, the first place I'd look is the connection at the resistor....
    Jan 2011
    az
    Injectors are new..
    Jan 2011
    az
    They are fic high impendence so no resistor box is needed.
    Medford OR
    Quote Originally Posted by keo92stealth View Post
    That doesn't negate the need to check if they have adequate current available to fire them...
    Jan 2011
    az
    Correct.. So if they aren't getting current to even fire them, what's the next thing to look at?
