What motor/car is it from? a vette, right?
I am currently running 3.5" blow through. Thinking about converting back to draw through and the 3.5" maf is too small for the intake bubble.
Pretty sure the 3.5" fits in stock bubble alright. Does the 3.5# gm maf fit stock intake bubble - 3000GT/Stealth International Message Center
But if you're hell bent on the larger of the 3: FULL THROTTLE SPEED - 85MM ZO6/LS6/TRUCK STYLE MAF SENSOR
Used: gmmafparts [ECMTuning - wiki]
Air Flow Meter Silverado 1500 Pickup 1172269 99 00 01 02 03 04 05 06 07 Assy | eBay
it can fit with a coupler or two but i dont want to rig up something that could potentially leak. i have held them together and it is quite the difference in size.
thanks to your info, I found this.
Cardone Mass Air Flow Sensor (MAF) - Remanufactured 74-8411: You?ve found the best Air Flow Meter/Mass Air at Advance Auto Parts
(i get a discount at the store through my dealership)
this unit is a 5 wire unit. the first link you posted mentioned an adapter harness. is this how ray and everyone else with the 3.75" mafs did it? or is there a 3 wire 3.75"?
i don't think they make a 3 wire 3.75, you'll need the adapter.
No core for the amazon purchase! woot!
