Results 1 to 10 of 15
Thread: Digital Climate Control Help !!!
    Wut wut? verified
    New Berlin, WI
    My climate control has a problem. Everything on the touch panel/screen appear to be working perfectly. It only turns the blower motor on and shoot air out of the center vents. It also triggers both my radiator fans to come on all the time.
    Background: is has never worked since I owned the car.
    What I've done so far:
    • Swapped the computer which mounts under the glove box
      Swapped the computer under the touch panel
      Swapped the touch panel
    Nothing has modified how it functions. I have two cars so swapping parts is not difficult. (one car works perfectly.)
    Thanks for any ideas...
    Member
    Brooklyn
    I say pull glove box, and what you can to see the blend motors, confirm the harness's are all plugged in
    We are a PROUD main event sponsor for NG 2011, 2012, 2013, 2014 - BRG 2012, 2013, 2014, 2015 2016 - ECG 2013,2014,2015, 2016
    YOUUSSS TRROOOLLLIN supporter
    Boston, MA
    check all 3 of the motors that are hidden under your dash. sounds like one may be unplugged or malfunctioning.
    -jeff
    1992 SVX LS-L
    1996 3000GT FWD-TT
    2005 XC90 T6 AWD
    i collect parts.
    Wut wut? verified
    New Berlin, WI
    Pulled glove box, found all three motors. I was able to move the arms by hand.
    Only the left side motor is moving by electricity. I just noticed an arm off on that one...
    Member
    Brooklyn
    pull radio also.. which you already did.. check these also..
    Wut wut? verified
    New Berlin, WI
    Behind the glove box:
    I think this goes near the top of the above picture... (missing the white plastic pieces though)
    Under the dash - missing a piece
    Behind radio
    PS: WTFBBQ rust?!?
    Member
    Brooklyn
    could be they are just rusted for some reason??? Maybe thats why they aren't moving.. they should move quite freely I'd guess. figure out what clips your missing , check against your other car.. and msg me what you need..
    Boston, MA
    wtf is up with that rust!?
    do the motors move at all? you might be able to munge up a coat hanger to do your work for
    Wut wut? verified
    New Berlin, WI
    Yea, the motors move freely.. except for the center one. The center one in the other car is the same way though.
    The rust is baffling. There is not rust anywhere else on the car. (Las Vegas origin) The exhaust system came apart in minutes.
    Is this a flood car?
