Hello everyone,
I have gotten stuck again on this PnP ecu; it has completely stopped logging my fuel trims. When first started playing with it, at the beginning of the summer, I did have the rears to look at, but for about the past 3 weeks, they are all just 0. There's no way they're actually 0. It's about 1300feet elevation here, I don't see 0 fuel trims being remotely logical.
I do have a battery disconnect on the car I usually leave disconnected overnight BUT, for the past 2 weeks I've been driving the car every day (waiting on parts for the DD... Doing the head gasket on a 93 mirage) and have left it on the whole time.
I've searched through the evolutionm forums, and the closest thing I can find is a non responsive O2 sensor, but according to my logs, I do have variance from 0.2v to 0.7v.
I've tried un installing and re installing evoscan, but that didn't make a difference.
I'm also having an issue with a low load misfire (@ 9in/Hg vacuum, and from 2-5psi boost) that's definitely in the tune somewhere that I can't get rid of as well. I know it's in the tune, because when I put the factory computer back in(non flash ecu), it runs absolutely perfect. I have no idea if these issues are related, but I figure they're worth mentioning anyways. Does anyone have any idea why every other aspect of evoscan/ecuflash work, but logging the fuel trims? Any help would be greatly appreciated. Thank you.
