I appreciate the compliments, definitely don't recommend doing it like that though. That was basically 2 years worth of parts collecting via people liquidating on the forums and eBay. Would've rather had a couple thousand more to spend on parts to forge and replace the rods and pistons, as well as having a more controlled climate within which to do the build. Of course, after I had reassmbled the motor, a few people parted out forged bottom ends on the cheap so you know..Patience is key.
This is definitely not a permanent rebuild, but hopefully will hold up until I can afford to build it exactly how I want it (Dr650s or 750s in WRX compressor housings anyone?
Rebuilding a car yourself has the same compromises as the car: Cheap, reliable, fast. Pick 2.
If you get reliable parts cheap, you probably won't be done rebuilding fast.
If you get fast parts cheap, you probably won't be reliable.
And if you get fast and reliable parts, it likely won't be cheap.
