Page 7 of 16 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 152
Thread: HELP! I think I bricked/stuffed my FlashECU :(
  1. #61
    Ill get a picture of the obd port to confirm wires are where they need to be.
    Error on my laptop didnt give me a code, said opening port, init sequence 2, sequence ended (or along those lines on the phone right now)
    Certainly thinking there is a pin out of whack in this harness.
    Ah well, small steps!
  2. #62
    Yeah that behavior is caused by the flash wire not hooked to the tactrix
  3. #63
    Mmm, it's making and more sense now. Plugged in a 2.5L DOHC ECU and she fired up and had beautiful idle AFR's. under load she didnt wanna work. Sputtering all over the joint. Probably cooked the plugs, so I'll swap those out next week, in the meantime she can sit again!
    Shit picture of the rear
    And a decent picture of the front
    So yeah, 91 Harness (1G) into the 99 ECU
  4. #64
  5. #65
    Also, you really don't understand how much I do appreciate everyone's input here. In a time where the car's been off the road for a year, then for me to brick an ECU and have to get the car towed home after the new exhaust.......well yeah, means alot to be getting help to find a resolution!
  6. #66
    Spent the last.....2 hours....probably looking in the wrong bit of the internet, can anyone confirm what wires go where from this ODB2 port into the flasher harness?
  7. #67
    Also just been told current ecuflash doesnt work too which *might* explain some things....anyone know a version which DOES work?
  8. #68
    94 3500gt vr2? verified
    NC
    Quote Originally Posted by TUFFTR View Post
    I can send you the version i'm using.
  9. #69
    I just flashed my ECU a few times the other day with the current version of ECUFlash.
  10. #70
    Forum User supporter
    May 2013
    Fruita, Colorado
    I'm on the newest beta version and I can flash just fine.
