Hey guys,
I am looking to do something to prevent rust on all of our cars. I just got a daily driver that is very clean underneath and I want to keep it that way. The VR4 is also fairly clean as is my girlfriends car. Looking to make these cars as easy to work on as possible and minimal body work in the future.
I found this stuff called Corrosion-X that is supposed to be pretty good. What do you guys think of spraying that all over the bottom of the cars?
Any other suggestions?
The 3000gt comes undercoated pretty well from the factory compared to other cars I've seen. Either that or mine was undercoated before. But it's a thick semi gooey stuff. I can press my fingernail into it. I actually am trying to find something that compares to it to do my truck. I used por15 on that last year then sprayed 12 cans of bedliner over it. Overall it worked pretty well but I want something with thicker protection. I was thinking of touching up the framerail again with the same process, and then using some kind of oil/tar undercoat for the rest of it.
