Okay, took a look: the front carrier bearing is definitely sloppy and sagging, and the second one is not too far behind.
Could be my culprits knock-wise, for sure.
What are they worth, and is Cherry Hill my best bet?
Also: timing was spot-on.
Order a boot/lube kit for the lobro too as it has to come apart for one of the carriers-
Suggest comparing price of parts & labor of lobro overhaul vs a nice 2 piece DS
Revel in your time
91 AWD TT
I was quoted $50 cheaper than an alumi-steel 2 piece, just saying...
Probably quoted for repairing the stock one vs a new 2 pc alum.
Quoted to rebuild the stock one with serviceable u-joints for $50 under the price of the alumi 2 piece.
I'd love to go light, but I don't have the cash until I get busy dumping some stuff on Ebay, guys.
