Results 1 to 5 of 5
Thread: Reinstalling my walbro - Question
    I have two questions, one is. What do you guys use to cut the "bell" that the FP goes into on the FP Assembly, right now I am using the stupid o-ring shit and I can never get it to seat right and when it does, it ends up coming undone and spraying fuel back into the tank.
    Second question is, if I dont cut the "bell" off to use hose clamps instead of the o-ring, How do you correctly install the FP with the o-ring? I must be doing something wrong. Tho is is my 3rd time pulling it in a year.
    Thread can be removed.
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Did you fix the issue? What was it?
    Yeah I fixed my issue, it was that the o-ring moved out of place over time, so I just bought a dremel and cut the bell off the assembly and used a rubber fuel line and two hose clamps and it fired right up on the first crank.
    ~2006
    Cool, I'm glad you fixed it! Thanks for posting your fix.
  • History
  • Information
  • Groups
  • Events
  • Resources
