Results 1 to 10 of 20
Thread: Blown Turbo(s)?
    Blown Turbo(s)?
    So I was heading to work, driving normally and all the sudden the car started to shake and wants to die. I pulled over and it eventually dies. I was in second gear going about 15-18mph. I started the car and it seems to run just fine, then I shift into first and tried to drive, it stutters real bad and dies. It eventually crawled to my friend's house which luckily was half a mile away, stuttering, barely make it pass 15mph. I notice that the needle on my boost gauge was pointing at the very max at 14psi, even though I driving very slowly in second gear, couldn't even get over 2000 RPM no matter how hard I press on the gas. The boost gauge needle doesn't drop down even when I let go of the gas, at which the car dies.
    So I'm guessing blown turbo(s)? Any input is greatly appreciated.
    Info on car:
    1994 3000GT VR4, 100% stock, except for clutch.
    174k miles, unknown on last 60k tuneup.
    1994 Mitsubishi 3000GT VR4
    100% stock... for now
    2001 Mitsubishi Eclipse Spyder
    Daily driver
    1988 Toyota MR2 Supercharged
    Running restoration project, also 100% stock
    RTBOOST verified
    Florence, Wisconsin
    It sounds like you either:
    a) have a severe boost leak that suddenly arose.
    b)your fuel filter may be completely clogged & barely giving any fuel up to the rails.
    c)you really pissed someone off recently & they poured something into your fuel tank that's now making its way through your engine.
    The stuttering and struggling to get up to speed makes me believe that it will end up being fuel related...As for what specifically is causing it, I'd test for pressure at the rails, replace the fuel filter for piece of mind, & hope that it isn't just your fuel pump dying.
    It's not that hard to change out, but if your car was ever driven in the winter or is stored outdoors chances are you'll be dealing with rusty screws, bolts, & fuel lines that all like to break off in the most inconvenient of places.
    EDIT: I would think that an excessive boost leak would probably be the most obvious cause for this, so do a pressure test as your first potential solution as it's the cheapest of the three.
    Sent from the garage
    Thanks for the reply and with so much info.
    Pressure test first thing when I get some free time this weekend. I was planning to replace the fuel filter anyways, so that would probably be the first.
    I seriously hope its not option "c". I do live in the shitiest neighborhood, 2 cars broken into, some stuff stolen from my yard, and a guy broke into my house while I was upstairs napping in the middle of the afternoon.
    Jun 2011
    Sweden, Gothenburg
    you should be able to get high rpm's even with blown turbos no? I mean na cars do. I could get high rpm's with one of my ic hoses completly blown off. About the boost gauge no idea. Idk sounds more like fuel or engine problems if you can't get high rpms
    classic blown off IC pipe.
    My money is here also
    You also might have a bad connection on the MAF sensor. Had this happen to me once. I pulled over and pulled the plug off them put it back on and the car ran fine after that.
    Also the stock boost gauge doesn't actually read boost. It shows what the ECU thinks the boost is at.
    Mad JDM Tite
    STL
    That's 3 for a intercooler pipe popping off, I would start wih the y-pipe.
    Wilmington, NC
    I'm saying y-pipe too. Its scary the first time it happens because it feels like its a catastrophic failure. I remember the first time I took my brother for a ride in my car after I put the 550cc's in and cranked up the boost...
    A little tire spin at WOT in first, slam it into second, then a really loud POP and the car gives its "dying breath" and stalls off. My brother is freaking out and starts apologizing and talking about how the car blew up, by this time I'm under the hood reattached the y-pipe, hop back in, crank it up, and look over at him with a blank face stare, haha.
    Anyway, get a metal y-pipe with rolled ends, a decent coupler, and t-bolt clamps.
    I'm going to say blown IC pipe or loose MAS plug.
    Even NA's don't run right when the intake isn't properly hooked up.
    let me clarify: stock boost gauge is basically a MAS airflow gauge. When you blow off a post turbo pipe, the turbos are free to just blow air right out, greatly increasing the airflow the sensor reads, making it show max boost while just trying to idle. If it were a preturbo pipe, the gauge would read low or not at all.
    as far as I care, the stock gauge is only good for telling you which side of the turbo the pipe came off, lol.
