Page 5 of 5 FirstFirst ... 345
Results 41 to 49 of 49
Thread: Front Suspension poly bushings
  1. #41
    FYI, make sure clockspring is centered as well when doing the steering wheel remove and re-install thing. it has a pointer built in, so it's easy.
  2. #42
    St.Louis
    Oh yea, i forgot to add that. Yea there is a mark that lines up and says "neutral" when it is lined up straight ahead. Ill add that into the post, thanks Chris!
  3. #43
    Jan 2012
    Arizona
    Dammit what pointer? I centered mine the hard way lol
  4. #44
    St.Louis
    On the clock spring there is a marker that says neutral, it has nothing to do with steering centering only the SRS and turn signals. Read near the end of the second post.
  5. #45
    St.Louis
    Just reporting in. Poly bushings are working awesome. The ones i made for the control arms are holding up just fine. Car feels very tight through corners and very responsive. Damn steering rack i bought off ebay is leaking like no other. I bet they forgot to cover the pinion teeth when it was rebuilt and tore up the seals =/. We will see how this lifetime warranty plays out from axle of dearborn.
  6. The Following User Says Thank You to Bloodlust182 For This Useful Post:
  7. #46
    Good to hear, sucks about the rack though.
    Dec 2011
    Iowa
    Are the smaller bushings on the k frame the same as the ones on the cross frame up front? Do I need to order two sets of the subrame kit in order to get the front most bushings also, or did you just reuse your stock ones?
  9. #48
    St.Louis
    Quote Originally Posted by jras312 View Post
    I reused the stock ones for the front piece, but yes they are the smaller ones from the K frame kit.
  10. #49
    FYI if anyone wants the part numbers for the larger bolts and what not for the new front subframe bushing, this is what i used(I didn't see them listed):
    18925 HCS 1/2-20 x 5.5 YZ8
    33817 SAE THRU HD 1/2YZ KG
    37084 1/2-20 Nylok NE YZ 8
    Google the each line to go straight to the fastenal page.
    I chose to go with a nylon lock nut.
    Thanks Bloodlust182 for putting this together!
