Well at 208k my cars front bushings are getting pretty worn out and I've decided to replace them all with poly. I am still in the process of testing out my findings and will update this thread as needed. Assuming you have dropped the front k member and control arms, that is where I will start explaining how to go about doing this.
The poly bushings that I sourced from Energy Suspension are:
Sub-frame bushings: 5.4105
Sway Bar Bushing: 9.5159
Control Arm Front location: 9.9482
The Control arm rear Location is sourced from GZP and is located here: Front Control Arm Bushing (rear location) for 3000GT and Stealth until end Sept. 93 | Ground Zero Performance
I also replaced my ball joints with Moog Part number K9855
Now The 4 bushings on the sub-frame can be simply hammered out with large punch shaped object and you should end up with something like this but probably Dirtier:
Now just grease up your bushings and slide them into their respected places. The ones closer to the front of the car are smaller than the rearward ones.
The sway bar bushings need to be Bent slightly to fit up against the sub-frame. I borrowed these images from Paul AKA Green-Lantern to show the bend needed.
You should end up with something like this:
Now for the Front Control arm bushings, To get them out I sprayed some pb blaster around them on the edges then hit them with a large ball peen hammer to knock them out. It only took a few good blows to knock them out.
Next, the modifications for the front bushing location. As seen in the following photo a tiny bit of the metal sleeve needs to be ground down or cut off and all but about 3/16" of the outer lip of each of the bushing pieces.
My sleeves ended up needing to be about 2.1" in length but I would cut them to the length of the spaces in your K-member so they fit properly. The bushings can be pressed in by hand, make sure to grease them amply and then the sleeves can be pressed in with a c-clamp. The final product:
The bushing sleeve ID is ~.5050 and our bolts are about .469~.470 which to me is too loose. I went to Fasenal and ordered some bolts that are ~.50 so they should fit much better. The K-Member holes are (from front to rear) .4780, .4840, and .5010. The front 2 holes will need to be drilled out but then the bolt should fit quite nicely. I will update this when the bolts come in. I will do the rear location in the next post.
Ok so the bolts came in from Fasenal today (8/19/13) and I am very happy with how the play in the arm has been tightened up. It is much more solid feeling in my opinion and was worth getting the bolts vs using the stock ones. Drilling out the frame took me about 2 seconds for the bolts to fit through the 2 front holes.
I forgot to take a pic with the washer and nut installed but you get the idea.
