Page 1 of 11 123 ... LastLast
Results 1 to 10 of 106
Thread: Fixed my boost issue.....but spun a bearing this morning
    Pueblo, CO
    Well, got my boost issed fixed, hit 25.7 psi this morning, went to get lunch and heard a faint knock when i pulled in to work. Reved it up a bit yup....shut it off. Just sad i guess. 3 years on this motor. Well, im going to sell it as a whole, then if not i will part it out. its in the for sale section
    pics and info
    3000GT / Stealth / GTO Forum - VB Pro Garage
    Ad
    http://www.3sgto.org/cars-sale/12742...24%248000.html
    Man vs 3/S verified
    Kingston, WA
    Gonna sell it for real this time?
    From the phone.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
    Banned J. Fast's Avatar
    Drain the oil first bro. Do you see flakes or is it just a "sounds like knock" situation? What did you change in the tune? What was your high boost problem?
    I don't bite
    Southern IN
    I believe he was hitting fuel cut with it set to only 19psi.
    Sin, did you ever log a pull so we could see what was going on?
    Pueblo, CO
    Drained the oil and no metal in the drain pan. Took the oil to work and had 4 of my techs and service mgr look also and nothing. so, gotta look at other shit now..
    yes, i did take some logs, but havent DL'd them to see. And yes, my boost issue was my fuel cut load was set to 19.88psi. changed that to 35 and hit 25.7 today .
    I've seen lots of spun bearing cars with no flakes in the drain pan. But then you pull the oil pan, and it's full of bearing material.
  7. The Following User Says Thank You to donniekak For This Useful Post:
  8. #7
    No flakes = didn't spin a bearing. I'm guessing you have a dead bank of cylinders or a dead turbocharger and what you're hearing is auto detonation from compressed fuel and no air or spark. When I seized my rear turbo many years ago thats what it sounded like... hammers. Replaced it and the sound went away. You spin bearings from oil starvation bro or assembly error those two problems show themselves really quick.
  9. #8
    I hope it's not a spun bearing man
    Cut the oil filter apart
    Sent from my RM-845_nam_vzw_100 using Tapatalk
  11. The Following User Says Thank You to Chris@Rvengeperformance For This Useful Post:
  12. #10
    I don't bite
    Southern IN
    Not true. I had ZERO flakes in my oil or filter, but had a rod bearing completely spun. Pickup was catching it all and clogged. I shut it down quick so that probably helped. Oil had a bit of a sheen though.
