Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Works Bell Air Bag Light Eliminator!
    Key Largo, FL
    I just yanked my bulb when I swapped the steering wheel. No need for a warning light for something I don't have anymore.
    2013 NG: 1st place, FWD Drags
    Medford OR
    Quote Originally Posted by 93STLTH View Post
    I agree... But if you had a 2nd gen, and wanted to keep the passenger bag functional, fooling the controller into thinking all is well would be the only way to do it.
    Screw the passenger! We die together! hah!
    Wrench Monkey Not Verified
    Rochester, NY
    Paperclip in the air bag plug should fool the SRS computer into thinking the air bag is there. Won't help your face when you crash, passenger should be good though. Haven't verified it on our cars, but it's standard testing procedure on many others.
    I've had the code 22 and the SRS light on since I bought the car 7 years ago. I should probably fix it, but instead I just won't crash it.
  5. #25
    Medford OR
    Nope... It will set a code 21 squib shorted code. Deliberately setting a short circuit code is a valid test if you're diagnosing an open circuit code, but I prefer to just use an appropriate resistor and get no codes if the system is working correctly.
    Specs are system specific, but the vast majority will set a shorted code anything under 1 ohm, and an open code anything over 4 ohms. I keep a couple 2.5 ohm resistors in my box just for that purpose.
  6. #26
    Sep 2012
    Decatur, TN
    Thelma and Louise?
  7. #27
    Thelma and Louise?
    Should have stayed in the kitchen
  8. #28
    Twin Turbo verified
    Melbourne, Australia
    There are very cheap scan tools on Amazon for the OBD2 cars that will clear the SRS error. Mine is on since I swapped out the stock wheel for the evo 5 wheel. But can't find a cheap scanner to clear the code on my OBDI system.
    SRS??? inspection - 3000GT/Stealth International Message Center
    Amazon.com: ELM327: Electronics
    Waiting install
    Build Thread
