Results 1 to 10 of 28
Thread: Works Bell Air Bag Light Eliminator!
    HID Retrofitter Not Verified
    Oct 2010
    Cupertino, CA, USA
    I was looking for camber alignment bolts for my car online, when I ran into this website. I haven't found what I was looking for yet, but since I am looking at aftermarket steering wheels I thought I would take a look at their selections, and it found this Air Bag Light Eliminator!
    Has anyone tried this before?
    There are good cars that get you from point A to point B, and then there are great cars, that get you into trouble.
    Advanced Tech? verified
    we don't have an air bag light... those are probably for evos to retain the side air bags
    West Islip, NY
    We do have an airbag light. That's what the SRS light is.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 4
    1991 Dodge Stealth ES
    - Sold
    Sold.
  4. The Following User Says Thank You to FluffyCow For This Useful Post:
  5. #4
    Banned J. Fast's Avatar
    The light only comes on if you have an impact sensor malfunction or a deployment. It doesn't illuminate if you swap out the steering wheel or disconnect the airbags. I have an aftermarket steering wheel in all my cars and no srs light illuminated when I swapped.
    The camber bolts you seek are called crash bolts.
  6. #5
    Avoca, NY
    To get this off topic, here are the bolts you need: Eibach Pro Alignment Kit - 3S - Maximal Performance
  7. #6
    Medford OR
    Are the bulbs burned out...? An open circuit in the squib sets a code 22 and turns on the SRS lamp.
    As far as the product listed, it's a 2-3 ohm resistor... Not exactly high tech or difficult to fabricate.
  8. The Following User Says Thank You to RealMcCoy For This Useful Post:
  9. #7
    if you remove the computer, nothing is there to turn on the light, lol
  10. #8
    Aug 2011
    Incorrect.
    I pulled a bunch of the interior out of my Spyder to do some leak testing on the roof. Including the steering wheel and airbag.
    I put the wheel minus airbag back on, and pulled out into the driveway. The SRS light came on at startup.
    I finished my testing, reassembled the car, and the light was still on. I had to clear it with my DRB2. There's also a fault code that can be tripped by a low battery / low charging condition. That one usually clears itself, but it sometimes requires a scantool reset.
  11. #9
    Yup I agree ^ definitely not true otherwise we wouldn't have to reset the SRS when our clocksprings break.
  12. #10
    Oct 2010
    Cupertino, CA, USA
    Quote Originally Posted by Maximal View Post
    Do those actually work?? I saw my local parts store had them, but I didn't buy them thinking they wouldn't work. How do they work compared to the OEM style?
