Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Corner Balancing/Alignment Questions
    No, there is deffinetly a middle ground between autox/street setup. The killer thing is the toe, but you can adjust your toe easily before/after an event in less than an hour.
    Banned J. Fast's Avatar
    Verify full suspension and steering travel
    Corner weigh
    Set front ride height
    Set rear ride height
    ^these two give you rake^
    Camber
    Caster
    Toe
    Adjust corner weight
    Weigh and align to your specific tires. Every tire has a different slip angle that will give you different grip.
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Does anybody know what size the hardware is that holds the tie rod on? Gunna have to go buy two 24mm wrenches but I am assuming the tie rod stuff is smaller (and hopefully I will already have it).
    Yeah it depends on what joints you have. May be around a 21.
    For the tie tods if you do not have a lot of wrenches just pick up a 12 inch crescent wrench.
    Sent from my RM-845_nam_vzw_100 using Tapatalk
  • History
  • Information
  • Groups
  • Events
  • Resources
