Just curious. I used 3 random, never seen if it matters
I done think it does.
I soldered a random three yellow wires to the blue wires in the harness before the connector to the coil packs so future jobs are still plug and play like stock. Red to red. Black to ground.
Doesn't matter, it's six isolated circuits in one box..
Did you fix the boost limit issue? You thinking it's ignition?
ya i need to put fresh plugs and retest. I tested my coil packs and my ptu and all were great. Just gotta do the plugs and drive it. just super busy with work and no time. So any wires is fine, cool
As stated, doesn't matter which 3.
-Chris
