Results 1 to 8 of 8
Thread: Euro Spec '99 Flashable ECU in a '91 GTO
    I am in the process of installing a Euro Spec '99 ECU (MD360029) into my '91 Jap import GTO.
    I have adapted a boomslang patch harness to enable me to do this, wired in with a OBD2 port using information from here, among other places.
    I can now read and write to the ecu, but cannot get it to fire up.
    I have disabled the immobiler by changing the code to FFFF and the ECU Periphery bit 03 to 0(is this correct????)
    One strange thing I have found is the rpm limit is set to 288461.5384615384rpm???????
    I can re-flash it to 7212rpm but it's really odd!!
    Anyone got any advice what to check etc???
    I will be re-checking my patch harness, going through each pin to confirm it's all wired up correctly.
    Marty
    Jun 2011
    Sweden, Gothenburg
    most likely the immobilizer that's giving you a hard time if the car isn't cranking up.
    ask blackstealth what to do with the code he knows.
    I have the same ecu and that was the problem for me. blackstealth helped disabling the immobilizer.
    I can always send you my files if you want.
    Quote Originally Posted by Ange View Post
    Yes please.
    Marty6470@aol.com
    Many Thanks
    Marty
    I ended up going to an earlier version of ecuflash, and used file that already had the immobilser disabled.
    Even that one had a stupid number as rev limit, but corrected that, and all is well.
    Runs just fine now.
    I will keep it at 360cc injectors for a bit, until I am happy it's reliable, then the 560cc evo injectors go in.
    Many Thanks
    Marty
    I lack color... verified
    Aug 1998
    I'm gonna ask that if my euro disassembly is gonna get passed around that anyone who uses it shoot me a donation.
    Jun 2011
    Sweden, Gothenburg
    I told him that in the email. Sorry shouldn't havet sent it without åring first.
    Marty dont pass the file around please.
    I haven't used the file you emailed me.
    I only opened it about 1min ago!
    And no, I will not pass it around
    Thanks for emailing me though, but got it sorted without it.
    Marty
    No problem.
    If I use it, I will donate.
    I will not pass it on.
    Marty
