Hi Guys,
I installed an NGK AFX wideband and have noticed it resets it's self after getting off boost. Seems fine when I've got the boot in but when I back off it resets and goes to the CAL screen then back to normal. I know it cuts out if the voltage drops below 11volts. Is it possible my alternator is spiking causing a too high voltage? has anyone else had weird issues. I have it wired directly to the battery with a rocker switch. The switch is rated at about 4amps from memory.
Cheers,
Joe
