Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: automatic vr4?
    ok thanks donniekak that helps a lot. I think me and others included thought the ecu from the vr4 might not communicate with the tcu for the shift points your referring to. I do know at the very least the ecu in the vr4 is different then the manual non turbo cars because the air to fuel ratios are set up differently for turbos and for the lower compression of the engine compared to the stock.
    but if the tcu can still get what needs from the vr4s ecu then I think we're in business.
    i never said the wiring is difficult--it's just a pain. that's why most people who have chosen to run ATX's ditched the tcu entirely and ran it manually. i wanted a stock-feel to it, so i chose to keep the computer in the loop. personally, i find that the tcu (on pwr mode) is quite capable to the task at hand; upshifts shifts at redline & downshifts in the blink of an eye.
    another issue i have with my car is having to hard-wire the fans ON. one more issue that could probably be fixed--had i been able to run a flashable ecu.
    Drives a UFO
    Grand Cayman, Cayman Islands
    I have exactly what you want! I bought a '95 N/A ATX GTO (all GTOs came AWD) and did a TT conversion on it. Then, I bought a shift box and a pair of paddle shifters and wired them in. For now, I have the paddles wired on the trim that covers the steering wheel column so they don't spin with the steering wheel, but I got a great idea on how to make a paddle shifter hub adaptor and install the paddles on the steering wheel. In order to do that, I will have to use the horn wires for the paddles and wire the horn on a separate button, somewhere on the dash.
    '95 Mitsubishi GTO AWD ATX - '99 front end conversion, TT conversion (19Ts), Forced Four shift box with paddle shifters, A/A wing, LCDBC, 3" straight piped exhaust with no cats and gutted pre-cats, Custom rear diffuser, HIDs, Carbon fiber steering wheel, 18" Mustang Saleen replicas.
    '92 Dodge Stealth ES - 3KGT body conversion. Sold!
  4. #24
    Drives a UFO
    Quote Originally Posted by hyper3000gt View Post
    It gets everything it needs. I am running a TT ECU in my TT converted N/A ATX GTO with shift box and paddles installed in it.
  5. #25
    Medford OR
    It would be awesome to see the flashable ECU incorporate the torque reduction strategy of the stock system... You could make the trans take much more power if it was shifting in a reduced torque mode,(think NLS for a manual) and recovered power when the shift is completed. The slipping and shift shock under full power is what burns up/breaks parts. Maxing out the pressure will increase clutch holding capacity, but increases shock loads tremendously, and puts hard parts at greater risk.
    As far as hardware, I know Brett's new ECU has all the components of both the SL and VR4 ECU, so obviously that can be done. I just have no idea where the software stands in the equation.
    Just another project for the programmers...
  6. #26
    that's pretty much what the TL shift kit is for. also, shifting in PWR mode means it will shift at redline...on the backside of the torque curve.
  7. #27
    Medford OR
    I won't disagree with you, but I think we're talking about very different levels... I personally prefer the TransGo kits, but the kit modifies the shift timing to reduce slippage and bindup, and increases clutch pressure and volume to minimize slippage. Running it up to redline drops it right into the torque curve after the shift. The entire idea of properly timed shifts is to keep the engine in the torque curve as long as possible. All that is great for car that is below huge power levels.
    None of that will save a trans from being broken by big power.... The primary solution to most failures has been higher pressures, and stronger parts. But due to the physical size of the trans, there are limits to it's torque capacity. I was just pointing out that the trans could be made to take some very big power with some creative software.
  8. #28
    i guess. i just know that DSM's are running them virtually stock (apart from a shift kit & welded spider), and they're taking 500-600whp regularly without issues.
  9. #29
    One fix at a time verified
    Kansas
    11SecondFWD ran DR-750s to high tens at the track with a stock ATX no shift kit, upgraded converter, or any internal modifications. He was making well over 550AWHP also and came within a few tenths of Ray's track numbers so I don't think anyone will discredit it holding the power of bolt-on TD04s sans a stock 4th gear WOT for an duration. If I had the space, time, and money for another 3S build I'd give the ATX a shot since it makes it so simple to run a faster time. Why do you think the GTRs do so well with no driver mod and anyone behind the seat? You can practically sleep behind the wheel because of the relative lack of driver involvementk and ease of use. 7-9k+ powerband you're in all the time plus lightning quick shifts makes it's great for drag racing if you can afford the entry price.
  10. #30
    that, and 4a33's are cheap. well, at least the w's are when you import them. the f's can be pricey when used....dunno why.
