Results 1 to 10 of 30
Thread: automatic vr4?
    automatic vr4?
    has anyone ever managed to put the awd automatic into a vr4? or are the awd tt conversions I've seen done start out as an already automatic SL just with the vr4s engine swaped in?
    Several people have done this. I believe there is a semi how to on the other forum.
    Corunna, IN
    I know of 2 running/driving Auto VR4 and an Auto TT in the works.
    '92 Stealth ES
    '95 Stealth R/T
    '93 3000GT VR4
    do you have a link to it? I'm just really curious how this is done. I understand how to make a turbo SL just by dropping in the engine from the vr4 with all supporting piping and oil lines and what not but installing the auto in a vr4 might be tricky. does anyone know if the whole dash would have to come out to install the necessary wiring? How does the automatic tranny's computer communicate with the vr4's engine ECU?
    has anyone seen baddvr4 around? I think he knew some stuff about this particular conversion.
    Appalachian Paradise
    All GTOs were AWD, even the N/A cars. N/A came with automatic, but still AWD. You can find one of those transmissions on ebay, and swap it in. Pretty straight forward. Don't know Alison's name on the forums, but she's got an AWD ATX VR4 running on the strip.
    yea I would like to speak with someone that's done it, so I know what all is involved I might be doing this conversion my self sometime soon, but I don't want to get in over my head. the main things I need to know is how difficult it is to put in all the wiring that's required for the awd tranny. obviously in a manual there is no wiring so I would have to put all that in my self and also get the proper ecu for it as well.
    does anyone know if this can be done only by working under the hood and just removing the center counsel or would the whole front dash from the inside of the car need to be removed to place the wires correctly?
    Oct 2010
    Coatesville, PA
    Quote Originally Posted by hyper3000gt View Post
    Thad or IPD has a conversion built car, but I think it's a SL body or Stealth with VR4 parts and automatic transmission. I may be wrong, but I'm sure he'll chime in...
    One fix at a time verified
    Kansas
    PM 11SecondFWD. He put a GTO AWD ATX transmission in a VR-4 and ran some high 10s at the track on DR-650s.
    sounds good thanks turbosincebirth!
