Results 1 to 8 of 8
Thread: Car Refuses To Start
    Jun 2012
    December 19th, 2011
    North Platte
    As you may have figured from the subject of this post my car refuses to start so here is what happened:
    I was making my way back from one side of town headed home and all of a sudden my car dies. No lights came on, no funny noises, nothing strange happened it just died while it was moving. Since there was no engine power there was no assisted braking or power steering so I simply slowed the vehicle down and muscled it to the side of the road. Luckily my friend brought his trailer and we towed it to my house. We checked to see if the timing belt was broken, it was in perfect condition, it has battery power because the stereo is on and the starter turns, we checked to see if the fuel pump doesn't work and it makes noise and works, we checked for spark and we had absolutely none and my spark plugs and wires seem to be ok, but I was wondering if it could be a nonfunctional coil pack (but NONE of the cylinders fire I didn't know if one dies they all do) or if its the ignition PTU malfunctioning and I need a new one, or maybe its a problem with the hardware on the ECU (Being its now 20 years old and its one of the older OBD-I's) and it needs to be physically rebuilt. Also note I have never tuned my ECU or tampered with it so its not a tuning issue. It has done this to me two other times but it either started as it was moving again, or I had to start it a few times and it would drop RPMs and die but after a few attempts it would start and run again. Please help I appreciate any ideas or experience you can offer --THANK YOU!!!
    Firestorm Red 1993 Mitsubishi 3000GT VR-4:
    ENGINE: BPU; HKS intake, HKS BOV, IPS turbo-back exhaust, Hallman Pro RX MBC @1.0 BAR, Blitz radiator cap, full vac reduction and EGR delete, Setrab front mount oil cooler, NGK Iridium plugs/MSD 8.5mm wires
    INTERIOR: Sparco Corsa seats, Momo Tuner steering wheel and hub, Carbing shift knob, Momo Quark shift boot, AutoMeter dual pillar pod with GReddy metric electronic gauges (boost, oil pressure), iPod Nano rig with Alpine head unit and Alpine Type-S speakers
    CHASSIS/SUSPENSION: Megan Racing Street coilovers, 3SX AWS Delete, 3SX Tie rod ends
    EXTERIOR: 100% OEM 1998 Conversion, debadged, shaved rear wiper and antenna, Wings West "hoop" wing, shaved rear diffuser, SHAD3S personalized plate
    WHEELS: 18x9.5 +38mm Enkei RP03s wrapped in BFGoodrich Semi-Slicks, ARP EVO 8 wheel studs, GReddy guenmetal lug nuts
    Super White IV 1995 Toyota Supra MKIV (NA)
    ENGINE: A'PEXi N1 cat-back exhaust
    WHEELS: Gram Lights 18x9/8 stagger (RAYS, bronze)
    Hopefully more to come...
    Jun 2012
    December 19th, 2011
    North Platte
    Also! I was wondering if I bought an all new ECU that had the OBD-I harness from a 1992 or 1991 would it work just fine in my 1993 or would it not?
    Mad JDM Tite
    STL
    Step 1 - Check your fuses in both fuse boxes. I recomend doing an electrical test on them to verify that they are good, don't just trust a quick visual inspection.
    Step 2 - Remove your ecu and inspect it for blown caps. A full description can be found by searching stealth316 and ecu removal.
    Step 3 - Verify that the engine is actually still in time. Just because the belt isn't loose doesn't mean that it didn't jump a couple teeth on the belt. This will require removing the crank pulley and rotating the engine over by hand until the timing gear is centered on the mark. Then check the timing marks on your valve covers and cam gears.
    Jun 2012
    December 19th, 2011
    North Platte
    -UPDATE-
    The problem WAS in fact, my ECU and I plugged in a 1992 Dodge Stealth Twin Turbo ECU in my 1993 VR-4. One problem now, it throws up that red CHECK ENGINE light. should I be worried about it? Or is this normal because the ECU was mated to a particular engine?
    Check the codes. If you don't have a logger
    Stealth 316 - Reading Diagnostic Codes - 1991-1993 3S models
    Jun 2012
    December 19th, 2011
    North Platte
    -UPDATE- it ran for a few days and now it won't even run after I start it. I'll put the key in the ignition and turn it to turn on electronics and the boost gauge will flick all the way and slowly drop to about the 6 psi mark then I'll turn them back off and turn it back on and the gauge will go to the 1-2 psi mark. Normally it sits at 0 psi when you start it I've noticed when it runs properly. So when I actually get down to starting it it will jump rpms then bog down and I notice the boost gauge is jumping all around making a "flick" noise then it eventually dies. I'll start it and give it throttle and this does NOTHING and it still dies. I noticed it is running super rich because after attempting the car simply smells like gas from behind. I don't know if this is a tuning issue, or a issue with the factory MAF or what, but I'd like some input because this car has been extremely frustrating lately.
    Sep 2012
    Decatur, TN
    Have you done a boost leak test yet? You could have an intake pipe blown off or leaking air.
    Have you tried disconnecting the MAF? That can help tell you if you have an intake leak or a bad MAF.
    Actually opened the ECU and inspected it?
    Do you still have your ECS connected? These can do weird things when they start to fail.
    Have you checked the physical timing marks to make sure that the car is still in time?
    Could have also had a CAS failure, which gives very similar symptoms to being out of time.
    Jun 2012
    December 19th, 2011
    North Platte
    I have inspected the old ECU and that's why it had problems earlier because it had blown caps. I put a 1992 Stealth Turbo ECU in my 1993 VR-4 and it seemed fine but the check engine light would come up. I'll check and see if I have a boost leak or if my MAF is bad.
