I may eventually get to a larger AR turbine housing, but I will be sticking with the 3" recirculated downpipe setup for sure.
Here's a good shot of the wastegate and downpipe setup:
The whole setup:
The whole setup:
I'm not well schooled in flow yet, but I would have thought the wastegate would have been smoothed into the downpipe better. There's enough room in the engine bay, I'd think. Either way, it's still badass, and probably easily flows enough for most power levels.
The wastegate dump back into the downpipe actually creates a nice venturi effect, and effectively corrects for the inefficient wastegate port placement/location. That's one of reasons boost creep becomes an issue when you go to a larger downpipe with an open wastegate dump -- you lose that venturi the system was designed to produce. The placement of the wastegate port relative to the flow is the real deficiency.
Ok, I can see that. Yeah, the 90* isn't good for flow... Do you have any idea of what the flow rates are through the wastegate at various boost levels versus the flow through the turbine?
Absolutely no idea.![]()
I only ask because on some setups it can reach 75% through the wastegate, lol. This doesn't look like one of those setups![]()
Its going to be a beast. I raced at 72mm Supra 6speed in fort Worth with my Whippled Shelby. I beat him but he did very good I bet he was on a street tune n 93 octane. I was running Torko and 18psi. We only went to 120 he might have caught me if we went faster. Supra can be beastly.
R.I.P Spyder you are missed.
93 VR4 453 Hp, balanced, Ported, Polished, Port Matched, 99 lifters, Ross 70 over 8.5 to 1 forged pistons, Stress relieved shotpeened magnafluxed rods,EK2 Red poly motor mounts, Fidanza Adjustable Cam Gears,Kevlar timing belt, Polished Fuel Rails, 16 T, Gutted Precats, 3SX performance down pipe, Race pipe,QTP Exhaust 3" Cutout, HKS Cat Back, MSD Wires, NGK BCP7ES non-resistor plugs, AEM EMS ECU, Speed Density Conversion, AEM 3.5 MAP, AEM AIT,Dual K&N air filters, Dejon Tool Dual Air Intake, Dejon Tool Y Pipe, PTE 550, Walbro fuel pump, EK2 fuel loop, No EGR, Vacuum line reduction, AEM True Flow Controller, Greddy BOV, AEM Gauge UEGO Controller wide band O2 sensor, Gauge-Tech, Kormex tranny,Quadco XR steel Output shaft, LSE Stainless Steel Transfer Main case and Midcase, Quadco input spool, Lightened flywheel, South Bend 6 Puck DXD F Clutch, Greddy EGT, Autometer Boost Gauge, 3SX fuel pressure gauge, Cross Drilled and Slotted Rotors, Ceramic Brake Pads, FMIC , 5Zigen FNO1R-C, Audio: 6 New Infinty speakers. Alpine CDA MP3/WWA 9847 Reciever, 2 Dual 300 watt amps. Cianci 3 gauge A pilars, Aluminum defroster vents' lowered
Here are few pics from today after cleaning up the engine bay a little -- still have a lot of polishing today. Everything is still mocked up at this point for fitment purposes (working on the water lines for the turbo). I have a shopping list of about a dozen misc. things I still need to order to get it finished up. I'm leaving on business Wednesday morning and won't be back until late Sunday, so I'm waiting a little later in the week to place the order. My plan is to have the car up and running weekend after next.
Looks very nice! It will be a great highway monster.
that's so cute and wittle!! AWWWWW!!!!!!
