I have a '94 3000GT 5-speed that has developed a miss. The miss is only around the 1500-2500 RPM range when I am accelerating. At idle and cruise it runs fine, and revs fine in neutral. A better way of describing the way it feels is if you are going up hill in too high of a gear. I do not have a check engine light to run for codes. Has anyone ever had this problem before?
