Results 1 to 10 of 15
Thread: Engine - 9:1 Ross Pistons, 4-bolt main, 1st gen heads w/ 1mm oversized valves - $2500
    I've collected a lot of parts over the years, now that I don't have a VR4 and I'm trying to self fund a business venture, I hope to sell them, even if that means selling them for less than they're worth.
    I'm sad to say that I need to sell this engine. I love this thing. I'm tempted to keep it for posterity's sake but I've gotta do what I've gotta do
    This would be perfect for someone who wants the benefits of a 2nd gen bottom end with the added benefit of extra low end torque from the 9:1 compression pistons.
    Here's the run down:
    • 9:1 Ross forged aluminum pistons
    • 2nd Gen block (4-bolt main, forged crank)
    • 1st Gen heads w/ Ferrea 1mm oversized valves
    • Stock 9b's
    • Stock Fuel
    • EGT Probe port in the rear exhaust manifold
    • Comes with an Autometer EGT gauge and probe
    • Roughtly 15k miles on the motor since the last rebuild (lost the papers though so I can't prove it)
    It engine was running strong the last time I drove the car that it was in.
    180 psi held on all cylinders before I pulled the motor.
    While the pictures don't show a plenum, it's only because I didn't have it on the engine at the time but it will come with one (and a plenum spacer from 3SX w/ bolts)
    May 2013
    union, ky
    what you looking to get for it?
    Engine mods: Duralast Gold battery, HKS SSQ BOV, K&N Cold Air Intake, 3SX custom Y-pipe, Megan downpipe-back exhaust ,EGR delete ,vacuum delete, turboxs mbc at 10psi, msd 8.5mm spark plug wires, denso iridium spark plugs
    Wheels: 17x9.5 Rota Grid fitted with bridgstone tires 225/35/17
    I'd like to get $2500 optimally.
    Fair price for a great plug and play.. My gf bought a long block that's it from Japan new for more then this
    If anyone has a 1st gen, this would be the perfect motor. It would be a drop in 4-bolt main with forged pistons and forged crank with 1st gen heads (using a CAS instead of Cam/Crank sensors).
    Sep 2012
    Decatur, TN
    Wish this had been around in the spring before I started rebuilding mine. 2500 is a steal.
    Wichita, KS
    Where are you located? Who did the rebuild work?
    91 R/T TT
    May 2013
    union, ky
    how many miles, are they oem springs or high rev? and its ready to drop in correct?
    Quote Originally Posted by akotten View Post
    I'm in Las Vegas. Lawless Machine, a Vegas shop, did the work on the block. Baker Heads (also local) did the head work.
    Lawless Machine is called something else now but I'm not sure what the name is. Both shops are highly rated and both do a lot of work on professional cars. Lawless Machine did the work for Factor X Racing who's NSX was constantly on top of the Redline Time Attack rankings. You can find info on both online.
