Results 1 to 4 of 4
Thread: dr650s...can't boost past 18psi
    I am having trouble boosting past 18 psi, it's a dr650 car with stock intercooler piping. I have a MBC but I have adjusted it completely out it does not change anything. I make 20-22 of vacuum at idle but do you guys thing it could be leaking at that pressure? I do get some needle flutter..
    Canaan NH
    First thing to do would be to run a pressure test on the whole system.
    +1 - test for leaks!
    Dec 2005
    Williamsport, PA
    Do you have the supporting mods to run 18PSI from a set of DR650's??
