Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Opened up my gearbox after hardcore road racing on 800ft/lb tq engine.
    Banned J. Fast's Avatar
    This is the third gearbox I’ve seen with expelled shift forkroll pins. I think when they get hot and vibrate the pins work themselves loose. I road course this gearbox and lean on it REALLY REALLY hard with no lift shifting and full on driving to the limit. I slowly started losing 3rd gear last week while making large left hand sweeping turns registering in the 1-lateral-G range. After about 120 consecutive laps third gear began to sneak some grinding. After about 140 laps I was consistently grinding and then suddenly I was blocked outof gear entirely and 3rd gear disappeared altogether. I opened up the gearbox and these were my observations.
    Shift fork roll pin is expelled on one fork (it snapped inhalf when I tried to pull it): gahh: The roll pin worked itself out it allowed the shift fork to slide toward the end cover about 5mm. I observed the fork resting on 4th gear entirely. It was locked below the hub/slider keeper step and consequently didn’t have enough reach to grab third because of how far it slid down the shift fork rail. At first I thought I rounded all the teeth on third gear because I ground it at least 20 times at 7500 rpms and then I finally whizzed the gear and it hummed for a second or two and blocked me out. After further inspection the gear/hub slider teeth are in good shape and it appears I just need to replace the synchro. I also discovered I melted the oil splash pan at the mount. Also appears the adjacent shift fork roll pin is starting to work itself out also (it’s projecting about 3mm).
    Surprisingly, I didn’t observe any metal flakes or chunks in the gearbox or in the fluid I drained. Just before I hit the road course I drained my Mitsubishi OEM Diamond Gear Lube and swapped in Royal Purple 75w-90 Full Synthetic Hypod Gear Oil. Can't say wether or not the full synthetic was a contributing factor. For the most part everything else in the gearbox is good to go. The synchromesh looks good on 3/4 but I’m going to swap in new synchros for my own sanity.
    Weak, old roll pins, or metal is just being flexed enough with extreme use they move out of place?
    You got lucky... Taz popped the box when his DID engage both gears at once
    guess it's time for upgraded pins
    1996 GTO, Owner since 2003.
    If you look at the first picture, you can see the roll pin is starting to work itself out on the 1/2 shift fork. You can also see that the 2nd shift rail over is projecting a little bit higher than the others. Thats the fork binding on 4th gear.
    These are the original shift forks. They have never been disassembled or modified. What I was most surprised about was how brittle the roll pins are. When I tried to pinch them with vice grips they snapped and when I tried to punch them out they chipped. I'm going to have to add opening my transmission and checking the roll pins to my nut and bolt list.
    Medford OR
    I would assume it is the usage that contributed... That is not a real common failure. I have seen it happen on the selector shaft a few times, and I do feel the pins are a little bit suspect in their construction. My fix for the selector shaft is some thick wall spring steel 1/4" roll pins. You have to ream the hole slightly to use them as the factory ones are 6mm, but I've yet to see one move... I guess maybe it's time to consider the same treatment for the forks.
    The thick wall single wrap pins also allow you to drive a second smaller pin through the middle if you need make them even tougher...
    I don't remember where we sourced them, we've had them on the shelf for years, be they appear to be very similar to these: 1/4" x 1" Plain Finish Steel Slotted Spring Pin | Fastenal
    Good info, Jer! Glad it's something fairly easy to fix.
    www.stickyvinylgraphics.com
    Custom Stickers & Graphics
    www.chumpcar.com
    Seen it several times on cars that are drag raced. Bang the gears an that is a possibility, also broken select forks.
    It would appear the spring pins have undergone some type of annealing process but when heated they relax? I'm thinking maybe solid pins would be siffice to aid in keeping them from walking out? What about swapping the spring pins out for a tapered dowel and inserting a cotter pin? I was actually having a conversation with my dad about the issue this evening over dinner. He metioned in old muscle cars they used to drill holes and use tie wires on pins, dowels, and any bolt they didn't want to back out. I think that's a good idea but we're talking about potentional interference due to close proximity to gears... I would like to use something that won't temper and become brittle and snap later on. Any ideas on a fix for this? I don't think new pins are the answer...but? Open to discussion. What works?
    safety wire and bolt if enough room, or maybe a clevis pin....I'll have to take a look and see if there is enough room there. 100 ways to skin a cat...
