Looks too good/expensive for anyone on 3si to buy lol (truth hurts)
1996 GTO, Owner since 2003.
I can build for $150 each. Not that expensive. Good insurance and a nice functional bling item.
The transfer case mod is ths best idea I've seen for a long while!.
For the roll pins, can't you dot punch 4 times around the fork after install to stop them backing out?.
www.stickyvinylgraphics.com
Custom Stickers & Graphics
www.chumpcar.com
Stock transmission has a plastic battle underneath the check valve. When the plastic gets hot the baffle falls out and the tranny breather system is left without a windage tray to capture the oil vapor. The vapor climbs up the check valve and clogs the little one millimeter hole and prevent the transmission from breathing and it blows the seals.
I'll post up some pictures of the windage tray/baffle and the condition of the vents. Any breather that's installed right there on the transmission will eventually become clogged when a filter gets saturated with oil. The clutch vents are in close proximity to the breather cap. I'm thinking and oil soaked filter and fine brake dust is a recipe for a clogged breather. You have to check it out bro, it's pretty slick!
Wow, really? Mine has basically a metal tube that had a black plastic cap on the top of a steel tube that looks to be press fit in the housing. I pull the cap off and ran a hose up to a basic fuel filter that I cut the top off of. I think you've seen it.
Looks like this little gem.
http://www.arkansas-ope.com/GPS_0F0106_FUEL_FILTER.jpg
I filled the tranny with it once, took forever too. haha
I'd really like to see yours, you have the 6 speed?
It probably took forever to fill because you still have a windage tray or partial windage tray in the transmission itself. The orfice is only like a millimeter. Its severely undersized for high-speed high heat application. It's definitely a breather restriction. How long did it take to fill your transmission up with gear oil through that little 1mm hole with the stock baffle installed, haha?
Id be interested in a can for the TC if it would be possible to refill the TC from not under the car lol.
