J, you gotta quit typing in black, I can't read it!!
or go to the very bottom left of the page and select "light GTO" style from the drop down box.
Functioning as intended.
I know this is an old thread, but I have a box here that the roll pins have backed out of. When I install them I use loctite, but I'm not sure if that is enough for ones that have tried to walk out already. I'm thinking of taking this approach and wondering what you thought:
https://www.jackstransmissions.com/p...pra-v160-forks
Did some research and the issue is finding the right size bolt. 1/4" leaves only .010" thread engagement, the hole is too big already. 5/6 or 8MM seems big enough to compromise the strength of the fork, so I'm not sure there is a solution. There exists such a thing as a 7mm bolt, but it is hard to come by, especially in high strength.
I thought you wanted M7 bolts?
