Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
Thread: Opened up my gearbox after hardcore road racing on 800ft/lb tq engine.
    Looks too good/expensive for anyone on 3si to buy lol (truth hurts)
    1996 GTO, Owner since 2003.
    Banned J. Fast's Avatar
    I can build for $150 each. Not that expensive. Good insurance and a nice functional bling item.
    The transfer case mod is ths best idea I've seen for a long while!.
    For the roll pins, can't you dot punch 4 times around the fork after install to stop them backing out?.
  4. #24
    …and so I designed this remote expansion setup for our applications, however, it's universal for any differential, transmission, and t-case breather setup on any vehicle . I had some push-lock brake line fittings custom machined and tapered to bolt directly into the t-case and tranny without drilling either. What do you guys think?
    Here’s what my surge tank design looks like. It's a 2" diameter cylinder with two baffled chambers in the shape of an inverted "U". One side has an overflow drain, the other side divided by an internal baffle is the expansion entrance. The one depicted has push-lock brake/oil/gas/gear oil rated hose. The lines were pressure tested to 100psi at a temperature of 300 degrees. At the pinnacle there’s a single gold anodized mesh and carbonized breather.
    That’s my final drivetrain and gearbox fix… Any interest in this item for retail?
    These look familiar! Pretty cool. You don't need one for the tranny though, just a good filter on the end will do it.
    Catch cans are always a hard sell buddy. Those that can will build their own. Those that can't don't know why they need them. :P
    www.stickyvinylgraphics.com
    Custom Stickers & Graphics
    www.chumpcar.com
  5. #25
    Sep 2012
    Decatur, TN
    Would be something added to my list long term to pick up whenever I get my transmission beefed up/rebuilt. Very good idea (and definitely nice bling)
  6. #26
    Quote Originally Posted by Erron Spalsbury View Post
    Stock transmission has a plastic battle underneath the check valve. When the plastic gets hot the baffle falls out and the tranny breather system is left without a windage tray to capture the oil vapor. The vapor climbs up the check valve and clogs the little one millimeter hole and prevent the transmission from breathing and it blows the seals.
    I'll post up some pictures of the windage tray/baffle and the condition of the vents. Any breather that's installed right there on the transmission will eventually become clogged when a filter gets saturated with oil. The clutch vents are in close proximity to the breather cap. I'm thinking and oil soaked filter and fine brake dust is a recipe for a clogged breather. You have to check it out bro, it's pretty slick!
  7. #27
    Wow, really? Mine has basically a metal tube that had a black plastic cap on the top of a steel tube that looks to be press fit in the housing. I pull the cap off and ran a hose up to a basic fuel filter that I cut the top off of. I think you've seen it.
    Looks like this little gem.
    http://www.arkansas-ope.com/GPS_0F0106_FUEL_FILTER.jpg
    I filled the tranny with it once, took forever too. haha
    I'd really like to see yours, you have the 6 speed?
  8. #28
    It probably took forever to fill because you still have a windage tray or partial windage tray in the transmission itself. The orfice is only like a millimeter. Its severely undersized for high-speed high heat application. It's definitely a breather restriction. How long did it take to fill your transmission up with gear oil through that little 1mm hole with the stock baffle installed, haha?
  9. #29
    It wasn't that bad, 15 minutes I'd guess? Whatever it's doing it's got to be enough or we'd see seepage coming from the CV's and output shaft.
  10. #30
    St.Louis
    Id be interested in a can for the TC if it would be possible to refill the TC from not under the car lol.
