Here is rod bearing #3-4
#3
#4
Again all are smooth, no groves, no copper. Slight blackening on the top bearing. Most of the blackening wiped off with a towel. The lines you see on the bearing are just the difference between the mirror polished part of the bearing and the stock dull gray that the bearings come.
Wondering if the Clevite bearings are just not 100% smooth out of the box hence the lines that develop during wear. No lines whatsoever on the crank itself. it is a perfect mirror polish. At this point I have zero worries that this engine was susceptible to spinning a bearing. I'm almost 100% convinced that the higher metal numbers are due to the over-sized Clevite bearings wearing in on the turned crank.
Re-installing these bearings and pulling the last ones. Then maybe the cradle to check the mains.
