They called me when they got the results from the engineer. They were worried about the lead and asked if I ran race fuel. I did run about 10 gallons of leaded 110 at the drag strip last year and have not changed the fuel filter since then. They asked if I had any oil pressure issues either, which I do not. they only found a trace amount of fuel in the oil which is good as that means fuel is not getting past the rings. they were also concerned with the Chromium as that is from piston rings. They stated it is high even for a new engine build, but seeing as that was the first oil change with any load on the engine I would expect it to be high as the piston rings are seating from the compression strokes under load and the vacuum from downshifting. So they recommended running it for 2k and sending in a new sample since I told them the engine runs fine. Now right before I took the sample is when I was trying to figure out the ECU issues, so for about a week or so I had been in the garage cranking the car, it would run for a min or two and die while I was checking things out trying to track down the problem that ended up being the ECU. Wonder if any of that flawed the sample at all...
