so i need some advice. heres the deal my property sits right next to my neighbors driveway on the south side of the house . well my neighbors driveway is dirt and has many dips etc that allow water to sit and saturate the surrounding ground instead of draining away. My south wall in my basement is leaking which sucks and im fairly sure its because of this water not draining away.
my proposed solution is adding a french drain/ tile on my side of the property line and running it the length of the house and emptying into a drainage field or rain barrel in the back yard . Does anyone see any issues with this or will this idea not help with the basement moisture at all?
