What type of vacuum lines should I buy? Can these be found in a regular auto parts store?
'95 Mitsubishi GTO AWD ATX - '99 front end conversion, TT conversion (19Ts), Forced Four shift box with paddle shifters, A/A wing, LCDBC, 3" straight piped exhaust with no cats and gutted pre-cats, Custom rear diffuser, HIDs, Carbon fiber steering wheel, 18" Mustang Saleen replicas.
'92 Dodge Stealth ES - 3KGT body conversion. Sold!
You can get vacuum lines from an auto parts store without too much trouble, a lot of guys just buy silicone vacuum hose though. If you want to run waste gate boost, run vac lines from each waste gate, as equal length as you can, to a T fitting (you can pick these up at an autoparts store pretty easy). Run a line off of the open port on that T fitting to the nipple on the Y pipe leading to the throttle body.
Since I have a GTO, there is only one O2 sensor. Well, on the OBX down pipe I bought, there are ports for two O2 sensors. In that case, could I use one of those ports for my wideband or should I install it somewhere else?
As long as the port is AFTER both turbo's merge then yes, that is fine for a WB.
Its mostly down to our crap fuel. Ive literally just got back from Vegas and noticed your V Power is rated as 91, our V power which is the highest rated fuel available here apart from full on race gas is 99.
Your fuels are much better at supressing knock than our junk![]()
After the merge is best, of course it will require getting a bung welded in down the pipe. If that's not possible for whatever reason (in my case the DP is welded to the catback so I can't take it anywhere as is) I would at least run it temporarily in the 2nd spot. Better than nothing. Get a bung put in after the merge as soon as is possible though.
