Hey guys,
I've searched around and can't seem to find any info on my scenario, so here goes:
I've been working on a '91 GTO TT, and saved my pennies, and a few months ago I bought my PnP flash ECU. Over the winter I've completed a wiring tuck, poly motor mounts, FMIC, Xfer case brace, and at the end of last year I did the complete 120k, oil pump, t belt, water pump, idlers, ISC, the works. The car ran pretty good on the stock ECU. Fast foreward to now, and after finally finishing up the exhaust and wideband setup, I'm trying to get this car back on the road. I've encountered a few problems that I cant seem to find an answer to, so without to much more of an essay, here goes:
I seem to have extra wires on my harness. The terminal that is used to provide +12v power the flash ECU (pin 77) already has a wire in it, a white wire, no tracers. Its a factory connector, with a quality crimp on a quality connector, so I assume its supposed to be there...? For the sake of the flash ECU, I unplugged it, and ran the +12v wire there anyways, and insulated it from contacting anything else.
The second extra wire is in my Diagnostic connector. All the instructions for installing the ECU showed that when you plug the other end of the red +12v wire, it would just plug into the open space. Again, I already have a wire there. This on is yellow with a red tracer.
The final thing that just doesn't want to work is ECUflash. I just unplugged and insulated that yellow wire at the DDL connector and I can now log with evoscan, but ecuflash refuses to work. I'm getting error " error loading FTD2XX.DLL " Can anyone help me? I've re installed both ecuflash and evoscan multiple times, in multiple different locations, manually installed drivers (I think, I'm not exactly a computer guru...), I've also tried both versions of ecuflash I could find, and still nothing. Thanks in advance.
Kyle
