Results 1 to 4 of 4
Thread: Logging fuel pressure
    JNS Engineering verified
    San Jose, CA
    I know some of you guys have engine mounted fuel pressure guages and you can read your fuel pressure at idle but can only read pressure under boost while on a dyno. Others may have a sending unit and a cockpit mounted fuel pressure guage.
    Some of us have to pass emissions testing and fuel pressure gauges in the cockpit or engine bay draw attention to the performance of the car "=racecar."
    I don't really want a gauge in the engine bay that I can only use on the dyno and I want to keep my interior stock as much as possible. My idea is to have a fuel sending gauge that we can wire into the ECU and log during pulls.
    I found a sending unit that could easily be plumbed out of sight in the engine bay and it has a linear resistance vs PSI characteristic. I could easily convert it to an analog voltage that could be wired to the ECU.
    First question is do we have any unused A/D converter inputs that could be used to accomodate a Fuel (or oil) pressure sensor? Second question is can we apply scaling / offsetting as desired within either Chrome or the Evoscan XML that would convert the voltage to a PSI number.
    Greg E, what do you think?
    I lack color... verified
    Aug 1998
    Already been done. It'll be released with the next version of chrome.
    http://www.3sgto.org/tuning-engine-e...-thru-ecu.html
    No ETA as to when exactly it'll be released. With my car being down, I've made 0 progress in further testing and development.
    San Jose, CA
    I just checked the V2 Tech manual and found a bad link in post #22
    http://www.3sgto.org/tuning-engine-e...al-sensor.html
    I'll go and add to the original thread, thanks.
    Aug 1998
    Yes I know. I'm working on the V3 manual which will be replacing that one so I haven't bothered much with updating the links.
