Page 48 of 55 FirstFirst ... 384647484950 ... LastLast
Results 471 to 480 of 544
Thread: Tuning my DR750s on Chrome
  1. #471
    JNS Engineering verified
    San Jose, CA
    What plugs would you guys run if you stayed on pump? I currently have stock NGK's in my DR650 build and pretty sure I need to go a step colder.
  2. #472
    ordered some Autolite AR3933's
  3. #473
    on straight pump I think the NGK 5671A-7 is still pretty ideal.
  4. #474
    San Jose, CA
    Thanks. I went with NGK BKR7ES. I was getting some knock counts so hopefully that will solve it.
  5. #475
    Did you ever try the NGK BCR8ES? I have 2 set to give a whirl when I figure out my issues.
  6. #476
    FYI rockauto has the autolite plugs for 1.96 each. I got 12 of them for $28 shipped
  7. #477
    I'm running NGK BKR7ES-11 with mine. About 20 psi so far, got them from Ninja for a great price. I'm sure you will have success with them Jim.
  8. #478
    no offense fellas, but lets not confuse this issue. The cold plugs are really necessary for e85 specifically. The success of your pump gas plugs does not carry over to e85 unless you want to pop your motor.
  9. #479
    I never said they did. I specifically referenced Jim in my post, because he asked about staying on pump. I don't have any experience with E85, so I don't pretend like I know what I'm talking about in that regard
  10. #480
    I don't bite
    Southern IN
    Ray, can you expand on what you have seen and what we should look out for on e85 plug temp? The suggested autolites are much colder than what other platforms are running in similar or greater hp range.
    Is this small frame turbo specific (td04/05) because of intake temps and backpressure when cranked up or does it apply to larger frame turbo setups as well.
    My understanding is preignition leads to catastrophic failure. Did you have to break some parts to find this info out?
    Thanks in advance for any additional insight!!!
