Page 42 of 55 FirstFirst ... 32404142434452 ... LastLast
Results 411 to 420 of 544
Thread: Tuning my DR750s on Chrome
  1. #411
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Thank you for contributing, don't take what I have to respond negatively.
    a)if I want to do this I may as well get "laggy" turbos.
    b)yes, it is already in the worlds. I will be running significantly less timing than the base timing tune and will pay particular attention to knock voltage at low rpm. I'm probably going to also start my 3rd gear "pulls" for tuning purposes around 3500 until it is really close to avoid unnecessarily beating on the engine. In real life it isn't going to spend that much time wot at 3000 in 3rd.
    c)This is possible, but kinda leads to A.
    Going to play it carefully, but at some point I gotta have faith in ray's engine. Surely an engine running 1000AWHP at 6000 rpm is going to be at least as stressed as one making 500 torque at 3500.
    I really have a feeling my mains were half smashed in the old motor before I started tuning it.
    I feel the same way you do.. it just seemed like people were suggesting bigger turbos simply to make power later to save the motor. Figured instead of reconfiguring your setup just to adjust the powerband, you could do those other things which would be a lot easier. Just in mind I didn't read the entire thread so maybe there were other reasons for considering 16Gs.
    I would definitely want to keep as much power across the board as possible though (obviously). I wish you the best of luck and look forward to seeing how things go!
  2. #412
    I will reward one internet cookie to whoever figures out what this update means. (limited to one dozen total cookies)
  3. #413
    Feb 2011
    Scottsbluff, NE
    You moved the Stealth to your new house.
    1995 Dodge Stealth R/T Turbo
  4. #414
    !!!! That is my exact dream Stealth configuration!
    2nd gen body with '96 wing and '99 headlights with 5 star chromies!
    She looks great! Congratulations!
  5. The Following User Says Thank You to J-Groove For This Useful Post:
  6. #415
    Quote Originally Posted by DK77 View Post
  7. #416
    Dayton, Ohio
    ...and it still isn't running, so it had to be towed?
    Bob.
    Stock 18" 6 Spoke Chromies
    Indiglo Gauges
  8. #417
    Quote Originally Posted by OhioSpyderman View Post
    Bob.
    correct, !
  9. The Following User Says Thank You to Chris@Rvengeperformance For This Useful Post:
  10. #418
    ~2006
    I was wondering why the front end had so much wheel gap..
    Congrats on the new house! Looks really nice, with a nice garage as well... And a really clean Stealth haha
  11. #419
    Sep 2012
    Decatur, TN
    Oh..Here I was thinking that you wanted to take the Stealth out for a cruise without getting it covered with road salt and putting miles on it.
  12. #420
    One fix at a time verified
    Kansas
    How much room in this garage do you have compared to your other? It still looks like it would be a little cramped working on a vehicle with two in there at the same time but it's more room nonetheless if the wife doesn't mind the SUV outside for a few hours at a time.
  • History
  • Information
  • Groups
  • Events
  • Resources
