Okay to summarize, he is what I think happened.
1)I had what I believe was a lean misfire around 4000 and 20-22 PSI. The wideband read lean.
2)I added fuel there AND gapped the plugs down.
3)Misfire seemed cured
4)ran into the misfire doing full 3rd gear pulls.
5)reduced boost
6)misfire gone, but was running mid 10s afr around 4000-4500.
7)leaned it out
8)made decent power
9)blew up the next day
10)???
11)anti profit?
So, what really happened is it was a rich misfire I misread by the lean wideband, which was caused by a misfire. I made it richer, but gapped the plugs down and the ignition was strong enough to fight it, causing unknown to me pre-ignition, beating out the bearings. By the time the tune was fixed the damage was done. If I had recognized things for what they were I could've fixed the tune and replaced the bearings and probably been okay.
All of this was amplified by the old stock shotblock making a lot of low end torque IMHO and the fact that e85 is bad for pre-ignition.
